How to replace exhaust manifolds???
Old Jul 3, 2011 | 04:39 PM
Adsan1280's Avatar
Default How to replace exhaust manifolds???
Hi All,
I'm looking to replace my exhaust manifolds on my 02 Land Rover Disco II and wondering how I can do it myself...If any one can provide me with a how to it'd be appreciated.
Also planning on replacing all four of my shocks so if any one can provide a how to on that as well it be great.
A.
Old Jul 3, 2011 | 04:49 PM
thospb's Avatar
This video makes suspension look slightly more easy than it really is but explains it well.
YouTube - ‪2in OME install‬‏
Old Jul 3, 2011 | 06:37 PM
First, how many miles on your truck, do you go off road much?
What is wrong with your manifolds?
If you are replacing your shocks and you go wheeling much, you should replace your springs also since they are warn out.
Who's shocks are you planning on using?
Old Jul 4, 2011 | 05:41 PM
Rovin4life's Avatar
if they aint broke don't replace them. but if they are noisy from loose studs then heat the truck up and take out the studs and use a 12 point 12 mm socket to get them off.
but heres a trick, use a stud puller and a torch to get the studs out. then use a thread chaser that is 8 mm and new studs and replace everything. its recommended you do both at the same time because you may have issues getting the manifold back on by itself.
Old Jul 5, 2011 | 11:56 AM
Adsan1280's Avatar
@Mike
It has about 108K miles on it. No, I have the truck for less than 3 months.
There is a noise that sounds a lot like an exhaust leak when I press on the accelerator with the car in motion - which leads me to believe that the manifolds or the manifold gaskets have to be replaced - plus there is whining/whistling noise that is coming from the driver's side wheel...Any suggestions??
No I dont going wheeling at all, but there is a bit of squeaking on the front and back shocks...also at the speeds of 50mph and higher the truck begins to bounce a great deal on a flat smooth road.
I have no idea who I should go with, but I am taking suggestions...I would like my truck to ride a lot like the Lincoln Towncar where you almost don't feel any of the bumps.
disc oh no
Aug 21, 2011 07:19 PM
Street Wolf
Jun 24, 2011 01:59 AM
meltdowndave
May 23, 2008 12:49 PM
Tastang
Nov 10, 2007 09:53 PM
riebs
Headers, Intake, & Exhaust
Aug 23, 2006 07:58 PM
