how to tow a discovery
I am considering towing my disco 2 (2002 no ace) behind our RV and need advice from anyone who has done this before. I am considering a front wheel lifting hitch, or a full car trailer if I can't do it with the front end lift. Has anyone done this before. THe front end lift trailer seems to be the most economical. Any help would be great. Do I need to do anything special to the trans. ect.
Thanks
Thanks
Rovers are full time 4x4 so towing on a dolly could do some damage to your trans case/transmission. If you want to use the dolly to lift just the front end and tow it that way you will have to remove the rear driveshaft while it's being towed. A full car trailer will have no issues, but as you said will cost a bit more.
