how to tow a discovery
Old Jul 19, 2009 | 01:51 PM
muddybuddy's Avatar
Default how to tow a discovery
I am considering towing my disco 2 (2002 no ace) behind our RV and need advice from anyone who has done this before. I am considering a front wheel lifting hitch, or a full car trailer if I can't do it with the front end lift. Has anyone done this before. THe front end lift trailer seems to be the most economical. Any help would be great. Do I need to do anything special to the trans. ect.
Thanks
Old Jul 19, 2009 | 02:05 PM
hazletbassist89's Avatar
Rovers are full time 4x4 so towing on a dolly could do some damage to your trans case/transmission. If you want to use the dolly to lift just the front end and tow it that way you will have to remove the rear driveshaft while it's being towed. A full car trailer will have no issues, but as you said will cost a bit more.
Old Jul 19, 2009 | 02:15 PM
oljohnboy's Avatar
i have a disco one, do his model have a cdl, can it be put in neutral?
Old Jul 19, 2009 | 02:49 PM
You either need to tow it with all four wheels on the ground or off the ground.
If you choose to do it with them on the ground then you need to put the transfer case in neutral.
All fours off the ground would be the best way to go.
mbruneaux
Jul 5, 2014 11:47 PM
Disco1.5
Apr 26, 2013 01:00 PM
308nut
Jan 28, 2013 02:33 PM
S4poor
Feb 10, 2008 10:15 AM
Johno
Jan 1, 2008 02:35 PM
