Hub removal
Old Jul 22, 2016 | 02:30 PM
Fallstaff's Avatar
I chickened out and paid a mechanic to do my hub — $285 Canadian.
360lbs of torque felt out of my league.
Old Jul 22, 2016 | 03:13 PM
Best4x4's Avatar
If mine were 360ft LB I must be one strong man! I popped a center cap off, inserted socket used my HF 1/2 32inch breaker bar and they loosened right up. These were OEM hubs I removed as well.
Well good news is it's over n done with.
Old Jul 23, 2016 | 06:44 PM
Fallstaff's Avatar
It was more the 360 ft/lbs needed to put it on again. That's important.
Old Jul 24, 2016 | 04:57 AM
OffroadFrance's Avatar
You can easily tighten to 360lb/ft without a special industrial torque wrench.
Use the correct sized socket with a T bar and tighten with a longish tube, typically, you would need to exert 120 lbs at 3'00" or 90lbs at 4'00".
Easy to calculate, 360lbs at 1'00" so divide 360 by 2= 180lbs, or divide 360 by 3= 120lbs, or divide 360 by 4+90lbs. Therefore exert 120lbs at 3'00" on the tube gives you 360lb/ft of torque at the nut.
Use a bathroom scales to check the amount of downward pressure/weight needed. Be careful the socket doesn't turn off the nut whilst doing this, use a G clamp or similar to hold it in place over the T bar. Better still get the wife to do it whilst you watch eh
Old Jul 24, 2016 | 08:54 AM
dr. mordo's Avatar
For the record, used the brakes to hold the hub in place, I got the nuts off with a Husky 1/2" electric impact gun, and put them back on by standing 2 on the cheater bar 2 feet from the center. I used a puller to yank the hubs with no problems at all. I think I might have tapped on the hubs once I had some tension on them to get them moving.
For me, by far the hardest part was finding the special sealant. I went to every parts store in south Miami before I finally found it at a NAPA. Finding the sealant took longer than the actual job.
Old Jul 24, 2016 | 10:38 AM
number9's Avatar
Do you remember what Brand/mfg/PN you used from NAPA?
Thanks.
Old Jul 25, 2016 | 07:55 PM
philnewell's Avatar
Originally Posted by dr. mordo
For the record, used the brakes to hold the hub in place...
I second that, I just had the car running and had the wife step on brakes, came off no problem with 24" breaker bar and me standing/jumping on the end (2ft * 200lbs + jump = 500lbs)
Same method to put it back on. (without the jumping!)
Old Jul 27, 2016 | 11:21 AM
CollieRover's Avatar
The 3/4" breaker bar worked great, and so did the PB Blaster. I have it down to the hubs on, but they are stuck as expected. I will just have to keep beating on the, until they pop loose. I tried to tap the bolts from the back, didn't budge it.
Old Jul 27, 2016 | 12:43 PM
Alex_M's Avatar
If you've got a propane torch, heating up the outside where the hub mounts (not the hub itself) may help loosen it up.
Old Jul 27, 2016 | 03:52 PM
X1 ..................... when the bolt lugs are hottish spray on some PB Blaster or Plusgas and leave to cool overnight then reheat the bolt lugs and try again with a six point impact socket on a breaker bar. Don't use a 12 point socket as they are useless on seized bolts and break easily or round off the bolt head.
