Hub removal
Old Jul 31, 2016 | 04:32 PM
  #31
dr. mordo's Avatar
Originally Posted by Alex_M
I've got to admit, I'm a little lost in all of this. Where are you all using this sealant? All the hubs I've replaced have been a straight unbolt and bolt back up procedure.
On these trucks, you apply a sleeve retaining sealant to the splines of the CV axle before pushing on the hub and tightening the nut.
Originally Posted by CollieRover
Well, at the auto parts store they thought I was nuts for wanting to put sealant on the hub. It was the first time they had heard of it, and had done many hubs in the past. As a perfectionist I would like to go backing and redo, but without a garage this will have to do. The hub has four bolts from behind and the axle nut on tighter than all get out. It's not going anywhere, anytime soon. If I have the opportunity I will remedy it.
The sealant seems like overkill, but obviously LR put it there for a reason.
In my experience, auto parts guys are almost worthless unless they've been doing it for 20 years and have learned thru osmosis from the mechanics who buy from them. I couldn't count how many times I've heard them give someone bad advice or an incorrect diagnosis.
That said, this sealant is pretty obscure. I'm guessing mostly machine shops use it these days, and they probly buy it in large quantities and not from Auto Zone. Like I said, I couldn't find it anywhere. If I were doing it again, I'd just order from amazon well before undertaking the job.
Old Jul 31, 2016 | 05:05 PM
  #32
Alex_M's Avatar
Interesting. I've not done that on mine, nor did I notice any removing the old hubs. I guess it's for keeping water put of the axles and stuff during water crossings and such, right? Because I don't have any oil leaking out, that's for sure.
Old Jul 31, 2016 | 05:19 PM
  #33
dr. mordo's Avatar
I guess it would kee water out, but so would a coating of grease. I think it is there to keep the hub from vibrating around on the CV shaft.
Like I said, I wouldn't be comfortable without it.
Old Jul 31, 2016 | 05:21 PM
  #34
Alex_M's Avatar
Ah, ok. I see. How strange, you'd think the 360lb/ft torque would do that pretty well.
Old Jul 31, 2016 | 06:31 PM
  #35
number9's Avatar
Please provide manual references or other LR document. I've looked but unable to find. Thanks.
Old Jul 31, 2016 | 06:39 PM
  #36
dr. mordo's Avatar
RAVE. Feel free to look it up yourself.
lmalbright
Dec 24, 2017 06:01 PM
chicane
Mar 26, 2016 02:04 PM
Charlie_V
Sep 5, 2015 09:14 PM
bagocheetohs
Jul 1, 2011 06:01 PM
djessopeng
Sep 7, 2007 06:28 AM
