Hub removal
#21
#24
#25
#26
I don't remember, but here's a way it could have happened:
https://landroverforums.com/forum/di...acement-46020/
then
STC50554 | LAND ROVER LOCTITE JOINING COMPOUND | Land Rover | | Britcar (UK) Ltd
then
permatex equivalent to loctite 648?
then
https://www.permatex.com/products/th...eeve-retainer/
then
then
then
NickAdams (07-31-2016)
#28
I looked at the tech data for both products, and they really aren't comparable. They are designed for different purposes, and so have very different characteristics.
The standard blue is a threadlocker, so it's designed to fill in tiny spaces and (obviously) lock the threads. I believe it is designed to be brittle so when you exceed the shear force it breaks apart and allows the bolt to rotate.
The 64000 is a sleeve retaining compound that acts like a glue to keep pieces from sliding apart. Due to the more dynamic nature of the joint (threads vs a sleeve), the 64000 is less brittle so it can flex a tiny bit. When I pulled my hubs, the sealant seemed slightly goopy, almost (but not quite) like silicone sealant.
So, what I envision happening is the blue threadlocker gradually disintegrates due to the hub shifting ever so slightly as you drive. Eventually the threadlocker is totally destroyed and now the hub's shifts are restrained only by the hub nut. If it fails due to the stresses it is not designed for, the hub eventually departs the vehicle.
I personally would have to pull it apart and use the right sealant.
#30
Well, at the auto parts store they thought I was nuts for wanting to put sealant on the hub. It was the first time they had heard of it, and had done many hubs in the past. As a perfectionist I would like to go backing and redo, but without a garage this will have to do. The hub has four bolts from behind and the axle nut on tighter than all get out. It's not going anywhere, anytime soon. If I have the opportunity I will remedy it.
The sealant seems like overkill, but obviously LR put it there for a reason.
