HVAC Blower Fan replacement '04 Discovery
Old Aug 3, 2022 | 03:50 PM
jastutte's Avatar
Default HVAC Blower Fan replacement '04 Discovery
if i'm replacing the blower fan do i need to pull out the entire housing or is there a way to take out the fan without taking out the whole housing?
Old Aug 3, 2022 | 03:56 PM
zski128's Avatar
You can drop just the fan, plenty of threads about this procedure.
Old Aug 3, 2022 | 04:10 PM
RA122125's Avatar
Banned
I hear you can upgrade it with one out of an 05 Chevy, and get much better air flow...there's at least a few threads about this upgrade too
Old Aug 3, 2022 | 05:28 PM
acg's Avatar
acg
This is a great step-by-step pictorial that I use every couple of years when I have to clean out my blower fan:
http://www.aulro.com/afvb/discovery-...motor-fix.html
Old Aug 4, 2022 | 07:22 AM
jastutte's Avatar
thank you! very helpful.
Old Aug 4, 2022 | 04:14 PM
jastutte's Avatar
dropped the fan today and had a hell of a time disconnecting the plug. turns out the harness side of the plug had burn marks and was melted some. burn marks on both plugs. i'm going to get some 10 gauge bullet connects and hook it back up to see what happens.
why would the connector melt but the fuse not pop?
i will be testing the fan itself by powering it directly to the battery but i have a new one on the way as a spare if not needed. i figure with 3 D2s i'll need it eventually.
Old Aug 5, 2022 | 08:47 AM
jastutte's Avatar
same day Amazon delivery of the connectors and i'm back on the road with a working blower fan.
now, if only i can figure out the ABS low voltage codes.
cacaca
Sep 13, 2020 03:42 PM
jamieb
Dec 17, 2012 08:13 PM
remember5
Jan 13, 2011 09:33 PM
jtb
Aug 2, 2010 03:17 PM
sdsilvere38
Sep 16, 2008 08:42 AM
