HVAC Blower motor help
After my recent rebuild I noticed my blower motor was making some odd noises. My suspicion (mouse nest) were correct. I totally cleaned the area out and reassembled. It worked great for a few days. Now it is dead. I pulled the electrical connector and plugged back in hoping it was a simple fix. That did not work. I am thinking maybe motor resistor but I thought when those go, the fan either works on high only or intermittently. How can I diagnose the blower motor resistor? Can you help me troubleshoot? Could it be a bad relay?
Thank you
Thank you
I faced similar symptoms last year... checked fuses, direct powered blower motor (and it works), etc. This is how I fixed mine (see last post):
https://landroverforums.com/forum/di...or-motor-85189
Good luck!
Good luck!
DiscoBuckeye (11-02-2018)
