I am NEW, with a problem!
I just registered today, hello everyone. I am now a first time Discovery owner, first time Land Rover owner. Not a first time 4x4 owner by far. I just traded my exploder (running fine) for a not so fine 1994 Discovery. They said they drove it home, and the next day they went to start it, it would not fire up. It does turn over though. Is there any problems associated with discoverys i should know about? I heard the Lucas ignition system on the 3.9's were prone to failure. Thank you very much.
What is great about the D1 is that it is fairly simple to work on. Spike is right, cehck for fuel and spark first. Use th eprocess of elimination, check the fuel first, then the spark at the plugs. The check the rotor in the distributor cap and then the coil. When it comes to the distributor cap and the rotor if it replaced with the cheap stuff it does not always work.
If none of that works then get back to us.
