I guess I did the induction cleaning incorrectly
Old Apr 24, 2009 | 05:25 PM
ainiguez's Avatar
Default I guess I did the induction cleaning incorrectly
I tried to do the induction cleaning using the vacuum hose at the top of the plenum, the one that goes to the distributor to suction the seafoam.
http://gallery.me.com/ainiguez/10000...12406112610001
While I let it sit for about 40 minutes I also cleaned the throttle body and other things.
I think I did it wrong because other than a regular-sized puff of whitish smoke when I turned the truck on, it never really smoked at all. What should I have done differently?
Old Apr 24, 2009 | 05:31 PM
AK Rover's Avatar
The hose you want to use is on the passenger side valve cover, off the PCV port. Use vise grips to pinch the hose and control the flow as the seafoam gets sucked in. If you do it correctly it will look like you're on fire as you drive down the road. After you have let the seafoam sit for a while drive down the highway until it all goes through the engine and the smoke stops.
The hose you used put the seafoam directly in to the cylinders with the air/fuel mix and did nothing for the rest of the induction.
Old Apr 24, 2009 | 05:35 PM
ainiguez's Avatar
Thanks. I'll try it again.
Old Apr 24, 2009 | 05:38 PM
AK Rover's Avatar
Restrict the flow so it takes 1-2 minutes to suck in the whole can of seafoam. I forgot about using the vise grips to restrict the flow and the whole can was sucked in in about 30 seconds.
Old Apr 24, 2009 | 06:39 PM
Camdisco24's Avatar
That is seriously the MOST important thing. You let it run in to fast, you've done it all wrong. Also, when you try to start the truck after letting it sit, it going to fight you a bit, but keep the key turned and it will turn over. Like AK said, you will choke small animals if you did it right, but you will feel the benefits!
TIP: Bring the bottle of seafoam with you if you go out on the main road, some people have been pulled over for excessive smoke and if you have the bottle, you'll be let off the hook.
Old Apr 24, 2009 | 10:57 PM
grussell's Avatar
Yea, when I did it a neighbor ask me if I was spraying the neighborhood for mesquitos.
Old Apr 25, 2009 | 09:49 AM
Suede's Avatar
Lol, I was worried about spooking my neighbors, so I decided to go near an open industrial area. At some point while i was sitting in the car waiting for a half hour to pass and listening to music, a motorcycle cop had parked between two buildings to set up his speed trap. Then I start her up and of course the smoke cloud from hell starts wifting down the block. After about 2 minutes, I hear a tap on my window and there is this motorcycle cop not looking at all happy about having to had made his way through the cloud of smog I'd just put up! lol
squid
Freelander
Mar 31, 2012 05:14 PM
happycamper
May 4, 2010 02:01 PM
KeizerRover
May 11, 2008 10:31 AM
Phototone
Apr 23, 2008 07:48 AM
Scanner
Mar 24, 2008 02:10 PM
