My 01 D2 keeps going off on motion after changing radiator hose
Old Apr 23, 2009 | 09:13 AM
dapo's Avatar
Default My 01 D2 keeps going off on motion after changing radiator hose
I had to change my radiator hose yesterday due to a leak, afterwards, i noticed that once in a while, my truck engine will just turn off even while on motion. Since it started, once i restart it, it will respond until a while ago it refused to start until after about five minutes of doing nothing. Pls any help will be appreciated.
Regards.
Old Apr 23, 2009 | 09:18 AM
leadfoot's Avatar
I don't think is directly related to the house, but of the sensors you messed up with, while replacing the house. More than likely it is the crank sensor.
Old Apr 23, 2009 | 04:19 PM
I agree with leadfoot, sounds like when your radiator hose blew your crank sensor got soaking with coolant and now it is toast.
A new crank sensor will fix you right up.
How mechanical are you?
Old Apr 24, 2009 | 01:31 AM
dapo's Avatar
Thanks for the responses, I actually was waiting for weekend to be able to take it to the workshop and get the codes, but when i called my tech, he said it could be the crank sensor. If its something simple to get to, I will surely be able to do it my self. I just hope its not too expensive. Pls tell me how to confirm that the problem is actually the crank sensor. Meanwhile, I have stopped driving the truck for now so as not to complicate the problem.
Thanks.
Old Apr 24, 2009 | 09:29 AM
There are no sensors that will turn the engine off, after starting it with the exception of the crank sensor, which was no where near the hoses.
By the way, did you properly bleed the cooanlt system after replacing the hoses, did you replac your t/stat?
PM me your tel number and I'll help you with this.
Old Apr 25, 2009 | 02:01 AM
dapo's Avatar
my number is +234-8055093299
Thanks.
Old Apr 25, 2009 | 09:24 AM
dapo's Avatar
Thanks all for the assistance so far.
I took my truck to the mechanic today, I told him to physically check the crank sensor, and he confirm that one of the screws holding it was loose and he fixed it, he then took out the fuel pump and washed it.
Then I took it to the diagnostic centre and they discovered that the airflow meter has error and we discovered that it was the connection that wasn't connected well.
so far after then, it hasn't gone off, I hope it remains like that, but the 'service engine soon' light has gone off.
Thanks.
Old Apr 25, 2009 | 10:12 AM
Wildhorse1966's Avatar
glad you got the problem fixed but i have never heard of someone washing a fuel pump lol
Old Apr 25, 2009 | 10:24 AM
I haven't either, he just got taken for an extra hour plus in labor.
Old Apr 25, 2009 | 01:22 PM
The crank sensor is about $60 at your local autoparts store.
How much did he charge you for one?
Tercan
Jun 20, 2017 08:43 PM
ryans97discovery
Oct 7, 2013 03:58 PM
Young
Mar 24, 2012 06:40 PM
nelbra
Sep 23, 2009 10:55 AM
chiasurf
Jan 31, 2009 04:28 PM
