I have the dumbest problems
Old Oct 6, 2012 | 04:47 PM
dr. mordo's Avatar
Default I have the dumbest problems
So, I dropped a nut from the Crank Position Sensor in my yard and can't find it.
I took the remaining nut down to the hardware store. It screws onto a 10-32 screw, so that must be it, right?
Wrong.
It's apparently some size that is a *tiny* bit larger diameter than 10-32 but with the same thread pitch. So, the original nut screws onto a 10-32 perfectly, but a 10-32 nut won't screw onto the CPS post.
Any ideas what size the nut is?
Old Oct 6, 2012 | 04:58 PM
jbkroh's Avatar
rememeber everthing is metric
Old Oct 6, 2012 | 05:28 PM
If you dont have a mechanics magnet buy one, if you dont have time to buy one then use a magnet from your fridge, go to the yard, start rubbing the grass, you will find it.
Old Oct 6, 2012 | 05:33 PM
Racer X's Avatar
Home Depot has an inexpensive model of this:
Amazon Amazon
Good luck.
Old Oct 6, 2012 | 05:39 PM
dr. mordo's Avatar
Well, it looks to be a M5 sized nut, which is almost identical to a 10-32. So I ordered a couple since I've hit every store in town and all they have are m4 and m6.
But I do plan to take a magnet out and look. However, it's raining pretty steadily which makes it hard to look, and I think increases the likelyhood that it'll get buried.
Thanks for the help. As much as anything I just needed to vent a bit.
Old Oct 6, 2012 | 06:08 PM
18" Rolling Magnetic Sweeper Nail Metal Pick Up Magnet Tool - Amazon.com
Good luck.
Thats what roofers use to collect nails in the yard after a roof removal job.
Here is what I was talking about, KD Tools KD Tools (Danaher) Swivel Head Telescoping Magnet Pickup Tool 16-3/4 to 26-3/4" - KDT2281 - Tools - Mechanics & Auto Tools - Automotive Specialty Tools, works great for retrieving dropped nuts and bolts that you cant reach, you know, when you drop them down into the frame or under the intake, etc.
FLA Rover
Jun 14, 2015 11:52 AM
nelsontod
May 18, 2012 12:20 PM
USMC_Denver
Apr 21, 2009 05:58 PM
pilsner
Nov 11, 2008 12:34 AM
