I have a problem with Discovery II clutch
Old Aug 16, 2013 | 05:06 AM
Stefan Vladimirov's Avatar
Default I have a problem with Discovery II clutch
Hello!
I have a question about the car LR Discovery II with 2.5 td5 engine. Is it possible, when changing the complete clutch, the friction disc to be mounted on reverse and to give unpleasant consequences after 1 year of operation in heavy offroad condition or the consequences will occur immediately after repair. If anyone knows the answer I will be glad to share it. Thank you!
Old Aug 16, 2013 | 07:17 AM
ZGPhoto's Avatar
You may have better luck on the Uk forums, we didn't get R380s after 1997 in the states.
Old Aug 16, 2013 | 07:19 AM
drowssap's Avatar
your question would be better suited for a UK board, there are no standard DII or Diesels in the states.
Old Aug 16, 2013 | 08:24 AM
Thank you very much guys! I will proceed to the uk forums.
Best regards!
Old Aug 16, 2013 | 09:43 AM
jafir's Avatar
the Australian forums are very helpful too.
Australian Land Rover Owners
Old Aug 19, 2013 | 01:11 AM
micky's Avatar
When the friction disk isn't mounted properly, the problems will appear right after the installation. The main reason for difficult gear change is an existing failure in the slave clutch pump.
Good luck!
buttocks
Dec 31, 2014 12:53 AM
niko
Jul 9, 2008 03:10 AM
cr355
Defender
Apr 2, 2007 08:54 AM
knickerlott
Feb 18, 2007 03:01 PM
domenico
Feb 4, 2007 11:12 AM
