I need help on a 2000 LR Discovery
Old Nov 6, 2007 | 10:53 PM
jofher's Avatar
5th Gear
Default I need help on a 2000 LR Discovery
Hello
today the engine light came on.
and i bought a Code reader.
The code was P0455
EVAP Emissions Control System Leak (Large)
Could some body tell me what does that mean?
and what i need to do?
Maybe some one had the same problem i have..
att
Jofher
Thank you..
Old Nov 7, 2007 | 07:49 AM
Default RE: I need help on a 2000 LR Discovery
If you were really lucky you might have a loose/failed gas cap. But most likely you have either a cracked line for your evap system or the purge valve is going out.
Old Nov 7, 2007 | 11:32 PM
jofher's Avatar
5th Gear
Thanks Mike
Ill check it out this weekend..
make shore that is nothing big to repair.
jepajo
Sep 9, 2010 06:51 PM
ibxsurveying
Apr 6, 2010 07:13 PM
jofher
May 16, 2007 09:15 PM
Airwolf1
Nov 6, 2006 04:27 PM
moshonas@canada.com
Aug 31, 2006 03:35 AM
