I need Pics of Underside of Roof Rails
Old May 10, 2011 | 08:54 PM
coors's Avatar
Default I need Pics of Underside of Roof Rails
Does anyone have pics of the underside (inside cab) roof with the headliner removed? Preferably pics of where the roof rails mount.
I installed my new roof-mount light rack and am trying to plan out how to run the wires off the roof and into the cab. A few of you are suggesting running the wires through the roof rails and into the cab.
On the top side (outside) of the roof - the roof rails look as though they are in two sections. The main rail, which is hollow and the 90's that secure it to the roof (seen in pic below with the bolt protruding out) which are not hollow. Unfortunately... I was hoping to get the wires down through on of the 90s.
Pics are appreciated!!
Old May 10, 2011 | 08:57 PM
antichrist's Avatar
What some people do who install an SD rack, or similar, is remove the OEM rails and run the wires down one of the holes left behind.
Old May 11, 2011 | 07:55 PM
coors's Avatar
The way I see it I have two options:
Option 1.) drill through roof
Option 2.) not drill through roof
Looks like I'll have to get creative
Old May 11, 2011 | 08:14 PM
ajmille's Avatar
if you dnt use your roof rails, I would drill through your mounting bolt . All you need is a steady hand or a drill press, then you can run the wire through, then connect your ground wire to the light bar.
Womble
Jul 30, 2015 01:58 AM
austinlandroverbill
Jul 24, 2015 12:00 PM
keoni004
Dec 6, 2013 09:15 AM
thehun
Mar 7, 2013 01:35 AM
avking
Feb 18, 2009 05:10 PM
