I plug welded a customers sleeves.
Old Jun 10, 2015 | 10:59 AM
  #61
ls1morethanyou's Avatar
i like turtles
Old Jun 10, 2015 | 11:16 AM
  #62
Fast951's Avatar
Originally Posted by Racer X
I disagree.
A competent machinist could drill the welds, remove the liners, weld the holes in the block, weld the compromise in the coolant jacket, re-bore, and insert new sleeves.
Would it be hellaciously expensive? You bet!
But it wouldn't be unrepairable.
Terrific. You can have that engine in your Discovery.
Old Jun 10, 2015 | 02:07 PM
  #63
TOM R's Avatar
well in the end it looks like a viable option to me and aparently others, chris thanks for sharing, i will also say my 4.6 parts came from chris and my visit to his shop made it very aparent they work on ALOT of rovers and have quite a bit of knowledge when it comes to repairing them
Old Jun 11, 2015 | 10:40 AM
  #64
Racer X's Avatar
Don't understand the doubt, maybe I just work with really good machinists?
That said, for the cost involved, I'd just grab a good 4.0L Bosch block and build it up.
Old Jun 12, 2015 | 05:47 AM
  #65
OffroadFrance's Avatar
Originally Posted by RoverMasterTech
This is what the weld looks like from the inside. (this is a cracked block I had laying around to experiment on.) The stainless wire sticks to the cast sleeve so well that when I tried to hammer the sleeve out it cracked the sleeve and didn't break the weld.
This is what the welds look like from the outside.
If your sleeves are moving, this seems like a good fix. 1500 bucks is a bargain compared to a 5k top hatted motor.
Good cheaper fix RMT and easier than pegging. Knowing exactly where to drill through is obviously part of the knowledge. Only issue for the future is if anyone wants to rebuild the block with new top hat liners but the majority end on the scrap heap way before then. 10 out of 10 for ingenuity in this case.
Old Jun 12, 2015 | 08:01 AM
  #66
lighting's Avatar
Why is anyone concern about the block been trashed after the repair? you can get a repairable block cheap, actually there is one in Craigslist for $300 in North Jersey, to me this is good fix, don't see it as a permanent solution like a top hat lined block but nevertheless a very clever approach. If someone don't have the budget to spend $5000 plus to rebuild an engine or perhaps have the common sense not to spend all that money in a vehicle that is worth $2500 after is fixed these is certainly a risk that I will take, well done MRT.........
RoverMasterTech
Jul 28, 2015 10:52 PM
Alex_M
Jul 14, 2015 06:31 PM
Spike555
ROAMING WITH FRIENDS
May 15, 2011 01:39 PM
01 Discovery SD
Feb 28, 2009 10:26 PM
rphotographer
May 16, 2007 08:52 PM
