I pulled the oil pump apart. Not cool
If you polish the crank by .01 then you go to .01 oversized bearings for the rod and main.
Cam bearings are different. If you go with new cam and standard new cam bearings, then you want new lifters. New cam=new lifters. Old cam = old lifters. Closest match is best.
