I pulled the oil pump apart. Not cool
Old Aug 18, 2019 | 02:17 PM
Fastercat's Avatar
Default I pulled the oil pump apart. Not cool
Is this common? 👀🙏🏻👀🙏🏻👀
Does this cover look too bad to reuse? I can feel scratches with my finger nail. I’m not sure what constitutes getting a new front cover.
Old Aug 18, 2019 | 02:27 PM
Best4x4's Avatar
I've seen worse, you can only really tell how it's going to work once it's back together with a new oil pump gear. How scored is the cover plate?
redwhitekat's Avatar
Were you having issues ?
Old Aug 18, 2019 | 02:32 PM
Fastercat's Avatar
To me it looks fine. But I’ve never done one of these motors yet. Lol
this is from the 4.6 I pulled from a parts truck to rebuild for my 2001. It never ran since I got it but I’ve torn it down and there bearings didn’t look horrible
Old Aug 18, 2019 | 02:35 PM
Fastercat's Avatar
Average bearing
Crank
Old Aug 18, 2019 | 02:36 PM
Fastercat's Avatar
I have a full set of stock size bearings and new cam and cam bearings. Was hoping to just polish the crank and install the new bearings.
Old Aug 18, 2019 | 03:29 PM
No Doubt's Avatar
You want to polish the crank and you want new bearings, but not in stock size.
If you polish the crank by .01 then you go to .01 oversized bearings for the rod and main.
Cam bearings are different. If you go with new cam and standard new cam bearings, then you want new lifters. New cam=new lifters. Old cam = old lifters. Closest match is best.
Old Aug 18, 2019 | 06:55 PM
cfz2882's Avatar
when I get mine apart for head gasket repair,i might go a little further and check the oil pump and timing chain...(2003,116,000 mi.)
Drducttape
Jul 27, 2019 07:53 PM
Squid4life
Dec 24, 2016 05:57 PM
Jeff Blake
Nov 22, 2016 02:32 AM
Jeff Blake
Jul 27, 2016 10:40 PM
Forrest
May 7, 2011 10:12 AM
