I would some advice on if I should use only the "premium" grade fules in my 04 Discovery
Good day,
I would some advice on if I should use only the "premium" grade fuels in my 04 Discovery. The type of engine is a 4.0 gasoline power plant.I currently purchase my fuel from Shell. My questions are:
1. is there a safety concern with regard to the engine if I do not use 91 grade fuels in my vehicle?
2. Can I use a lower grade fuel such as 89 grades on a regular basis?
3. If I use a lower grade fuel after using a 91 grade would there be any potential hazards to the power plant due to the difference in fuel in the system.
4. Should I use any type of fuel preservation or additives in any way with my vehicle?
Thank you all for your time and effort answering my questions.
RE: I would some advice on if I should use only the "premium" grade fules in my 04 Discovery
Yes, since you're already using Shell (good choice), use Shell V Power 93 octane. It doesn't cost that much more and you'll get your money back in mileage, performance, and avoiding future engine problems. This is one of the most-talked-about topics on the site, so if you want to see the reasons I believe what I just said, then do a site search for "gas mileage" and you'll get a lot of information.
on
1 Post
ORIGINAL: traffictech870
Good day,
Good day,
That's a good question. I"m going to find out to make sure. I've always thought that they were a 4L. I will pop the hood and check the owners manual and give you the correct information.
Seriously there's not that much difference in price. On my Blazer its like $4.30 per tank, and with the blazer's mileage, it would take upwards of 14 fill ups to get one fill up with just the money I saved by buying the cheap stuff. Thats 3000 miles!
Buy the premium, shell V power, and enjoy a nicely running engine for years.
(I only use the Blazer figures because I havn't yet priced out the figures for the Range..I just fill it up with the V power)
