IACV question
Old Mar 19, 2024 | 04:09 PM
Frank4's Avatar
Default IACV question SOLVED
I had a surging idle on cold starts, P0505 code. I pulled the IACV valve and inspected it. This is a BOSCH unit that looks original to the truck.
I had plenty of carbon build up so I sprayed some throttle body cleaner in both holes and now the flaps pretty much turn free as you rock the unit side to side.
my question is are the baffles/flaps supposed to move that free? It’s as if they aren’t connected to anything.
Thanks.
Old Mar 22, 2024 | 10:26 PM
Frank4's Avatar
No one has any IACV experience?
Old Mar 23, 2024 | 11:01 AM
jastutte's Avatar
been a while since i pulled mine, but i believe it did move freely. i have no idle issues.
Old Mar 23, 2024 | 04:38 PM
andino's Avatar
I have a couple good IACVs and once cleaned, they flap freely like that. I think they must be voltage sensitive to determine how they open/close.
Old Mar 23, 2024 | 05:04 PM
Frank4's Avatar
Thanks!
Old Apr 5, 2024 | 10:27 PM
Frank4's Avatar
Default Solved
I figured out the surging idle and the IACV code. I will probably start another thread about this because it has to do with another modification I had done earlier.
While trying to solve the surging idle and IVAC code I was reading posts from every LR forum I could find. I found a thread about surging idle and the fix was the oil separator valve which I had REMOVED during my last head gasket install. I removed it after reading a thread about this valve allowing too much pressure to build up and causing valve cover leaks( thats what I understood anyway), I also replaced the plastic connector at the intake that the hose from the valve cover connects to with a brass fitting.
I installed a new oil separator and the surging idle is no longer happening and the IACV code has not returned.
Glad to be able to post a solution. I hope this helps someone else and thrilled it cost less that $10!
Old Apr 6, 2024 | 03:05 PM
Harvlr's Avatar
Or do the PCV mod.
https://landroverforums.com/forum/di...4x4-mod-92942/
Old Apr 6, 2024 | 04:23 PM
Extinct's Avatar
Originally Posted by Harvlr
this is the way
Old Apr 6, 2024 | 07:12 PM
Frank4's Avatar
Yeah that’s the mod I did. If you read my follow-up post I replaced the plastic part at on the intake with the recommended fitting.
Old Apr 7, 2024 | 12:37 AM
Richard Gallant's Avatar
@Frank4 Just take it out and clean it every oil change - they can pack with crud up pretty quick
