Ideas, disconnects.
Old Jan 12, 2008 | 01:51 PM
Darover's Avatar
Default RE: Ideas, disconnects.
You can always install limited wheel travel straps is you ever end up with too much.
Old Jan 12, 2008 | 03:17 PM
ajh's Avatar
ajh
True, but I view straps as a temporary fix really. I think the cones and retaining will be enough if I stick with a 10" in front and a 12" in back, if it's not I can always just put in a 3" RTE spring set.
Old Jan 15, 2008 | 10:46 PM
ajh's Avatar
ajh
OK, finally got the front disconnects fitted. They sent the wrong ones though, the holes/pins were right but they sent the jeep saddles so I had to trim the swaybar mounting tab to get it to fit. I don't know if the Rover specific ones are different but the lower mount pins are very close to the axle housing on the passenger side. Probably going to weld on some extensions and drill new holes for the tapered pins to get it up and clear a bit to make connecting/disconnecting a little easier.
The ride with the rear springs (HD RTE) and front sway connected again is dramatically better. I don't know who thinks airbags and no front sway is sane.
However the rear swaybar is undersprung now. I'm going to try mounting the rear disconnects an inch up the swaybar with a new hole and saddle in a couple weeks when I get a chance since the new links are longer. This should stiffen up the stock rear bar, hopefully enough. The front sway is fine with the extended links, the back still moves too much.
Old Mar 6, 2014 | 08:22 AM
dusty1's Avatar
this thread is fairly recent........so in reference to ace. and still having it work properly,
I extended my sway links and am wondering if I made them toooo long. is that possible. I am just over 3" on extension. about the same as lift. i prefer to keep ace working properly and i don't want to crawl under my truck prior to going off road . any ideas? 3-3=0...right?
Old Mar 6, 2014 | 09:04 AM
ZGPhoto's Avatar
6 years = fairly recent haha nice Dusty.
3-3= remove the rear sway bar
Old Mar 6, 2014 | 09:18 AM
dusty1's Avatar
well,i did make some disconnects also. I just have not convinced myself to dump it. it is one of the few things that actually works well on my truck.
sidenote.....Zack, what do you have going on for stops on the rear? with that panhard bracket?
Old Mar 6, 2014 | 09:21 AM
ZGPhoto's Avatar
I hear you..sway bars do help quite a bit.
Right now I just have stock stops, but I will have tabs welded on the axle tube to mount stops when I install my 7100s
tigertrakstar1
Mar 5, 2014 04:13 PM
DiscoWest
Jan 7, 2014 03:56 PM
kamileon
May 24, 2011 05:10 PM
JHDisco2
Nov 25, 2009 04:16 PM
AK Rover
Apr 30, 2009 10:21 PM
