Identify plug on timing cover
There has been an engine oil drip since i purchased this 03. I got up under and saw this plug. I removed it by hand, and screwed it back in, but it stops and threads are showing. I snugged it up with a wrench, but it looks like the wrong plug. I thought this might be where an oil cooler would hook up because of where it is. Any ideas?
It is the large bolt right above the oil filter in the picture, if you look close you can see it does not tighten flush with cover.
RicketyTick
04-25-2014 08:03 PM
TheUninformedOwner
Freelander
04-15-2009 08:25 PM
