Identify plug on timing cover
Old Jul 21, 2015 | 10:33 PM
Joemamma1954's Avatar
Default Identify plug on timing cover
There has been an engine oil drip since i purchased this 03. I got up under and saw this plug. I removed it by hand, and screwed it back in, but it stops and threads are showing. I snugged it up with a wrench, but it looks like the wrong plug. I thought this might be where an oil cooler would hook up because of where it is. Any ideas?
It is the large bolt right above the oil filter in the picture, if you look close you can see it does not tighten flush with cover.
Old Jul 22, 2015 | 09:27 AM
You rate right, that was for the engine oil cooler your truck didn't come with. Might want to pul the plug and reseal it.
Old Jul 22, 2015 | 09:59 AM
Thank you Mike, shouldn't the plug tighten flush with the flat side? It stops halfway up. It stops like it is hitting something.
Old Jul 22, 2015 | 10:02 AM
I think there should be a metal crush ring type washer in there.
Old Jul 22, 2015 | 10:08 AM
I appreciate your time and expertise.
Old Jul 22, 2015 | 10:13 AM
mose802's Avatar
I had the same problem. I tightened mine and it stopped. I was told there was an o'ring that you can replace. Mine is not tightened flush.
Old Jul 22, 2015 | 01:46 PM
abran's Avatar
There is an o ring, I have not seen a crush washer on it.
The o ring is closer to the end. Same one the oil lines use.
A5scott
Jul 11, 2015 07:25 PM
RicketyTick
Apr 25, 2014 08:11 PM
RicketyTick
Apr 25, 2014 08:03 PM
tmtegt
Mar 20, 2013 07:31 AM
TheUninformedOwner
Freelander
Apr 15, 2009 08:25 PM
