Idle Air Control Valve
Old Nov 23, 2009 | 12:11 PM
me3ps's Avatar
5th Gear
Default Idle Air Control Valve
This is my current situation...my idle air control valve was making this high whinning sound, I took it off and cleaned it but it didn't really solve the problem. I purchased a brand new one, installed it and the whinning sound is so much worse than the old one. A little history: I have changed the MAF, alternator, water pump, spark plugs, and serpentine belt. Do I have a bad idle air control valve or is there some electronic promblems?
Thanks for your help.
Old Nov 23, 2009 | 03:03 PM
DI or DII?
Old Nov 23, 2009 | 04:35 PM
me3ps's Avatar
5th Gear
Sorry it is 2001 Discovery with 115,000 miles.
Old Nov 23, 2009 | 05:04 PM
Are you sure it is the idle control and not your secondary air?
Does it do it only with the engine running or when the key is on too?
Old Nov 23, 2009 | 05:45 PM
me3ps's Avatar
5th Gear
I believe it is the idle control. It happens when I accelerate and idling. I just don't know if the new part is suppose to make that noise till it is broken in or the system is resetting itself. The only codes I am pulling have to do with the MAF. It idles at the dash below the 1 (don't know if that is 800rmps). It is just driving me nuts because I don't understand why it is doing that.
Old Nov 23, 2009 | 06:09 PM
NO, there is no brake in time on new parts. Find out exactly what you put on and get back to us. Do you have any fault codes showing?
Old Nov 25, 2009 | 01:32 PM
me3ps's Avatar
5th Gear
Sorry took a few days to respond. Okay the idle air control valve doesn't make any sounds now (new one). Should I still think it is defective? The codes I am showing is
P0102 and P1884. The MAF is new. I have tried resetting the codes but they come back. I guess may questions are now...send the back the IAC and get a new one and how to fix those two codes.
Old Nov 25, 2009 | 08:12 PM
What brand of MAF is it?
Unless it is a BOSCH MAF they tend to not work correctly.
agthird
Dec 22, 2022 12:59 PM
harvy17
Jul 30, 2010 06:00 AM
Suede
Apr 28, 2010 10:07 PM
discoboy
Feb 7, 2009 04:56 PM
bearcatfans
Dec 18, 2007 09:01 PM
