Idle Air Control Valve....
Old Nov 3, 2010 | 09:23 AM
agthird's Avatar
Default Idle Air Control Valve....
wow cleaned that sucker up and eliminated a bunch of small problems...no codes but idles better shifts better and accelerates better...I used some throttle body cleaner and flush it out...any thoughts?
Old Nov 3, 2010 | 09:52 AM
yloDiscoII's Avatar
Thought : I think I'll try that myself
Is there any danger to cleaning it? Like, easily breakable pieces, etc?
Old Nov 3, 2010 | 10:21 AM
agthird's Avatar
it came out pretty easy whatever you do don't disconnect the black hose at the air intake it will break.. cheap plastic...I just detached at the iCV only...I sprayed the crap out of it....the metal clip on the back of the motor has to be popped off to completely remove it..do this last
Old Dec 20, 2022 | 04:44 PM
Txdisco2's Avatar
This thread just changed my rover’s life… my ICV was completely stuck. I was getting rough idle every time the engine was turned on, major shifting jolts to the point that I thought my driveshaft or transmission was the culprit. Half a can of throttle body cleaner, and a few tough bumps into a rag on a hard surface later….we have movement in the valve and an engine that runs AND sounds like it should.
It now shifts smooth as glass, and RPMs are not fluctuating all over the place.
thanks!
Old Dec 20, 2022 | 06:47 PM
Best4x4's Avatar
Yep they can get really gross!
Old Dec 21, 2022 | 09:08 AM
Sandman614's Avatar
Sprayed mine out yesterday, it actually didn't seem that bad. I reset adaptions after cleaning it. Unfortunately it didn't take care of the little stumble I have at idle.
Old Dec 22, 2022 | 11:53 AM
NVDiscovery's Avatar
What is the best cleaner for this? My gut tells me electronic cleaner but some have used throttle body cleaner and/or carburetor cleaner.
Old Dec 22, 2022 | 12:06 PM
Sandman614's Avatar
Or Brake Cleaner
Old Dec 22, 2022 | 12:54 PM
longtallsally's Avatar
This is on my list to do. When I did the throttle body heater, I cleaned up the TB a bit, but I’m sure I should do the same to the ICV. It’s good to see most have good results with doing this and since I put nothing but tractor gas in mine, it probably wouldn’t hurt anything.
Old Dec 22, 2022 | 12:59 PM
Sounds like my spray can of "Parts Cleaner and Degreaser" would do the trick. Thank you!
CodeRover
Dec 23, 2018 08:57 PM
harvy17
Jul 30, 2010 06:00 AM
alemurill
Jan 5, 2009 11:23 AM
vtrange
Feb 8, 2007 02:26 PM
awsherwo
Apr 28, 2006 01:52 PM
