Ignition Coil
Old Oct 1, 2009 | 06:28 PM
ainiguez's Avatar
Default Ignition Coil
I have a 94 DI. Recently it decided not to start. After checking, it turned out to be a bad ignition coil.
I would like to ask you gentlemen and ladies which of these coils you think is better:
1. Lucas "regular" $25 to $50 at different vendors
2. Lucas "high output" $73 at motorcars ltd
3. Bosch "regular" $73 to $100 at different vendors
4. Crane Cams PS20 "performance" $40 special order at Advance Auto Parts
there are others (duralast, etc.) but they are more expensive.
Does anyone know of another (good) one that is not too expensive?
Thanks
Alfredo
Old Oct 1, 2009 | 06:32 PM
Eurotrash's Avatar
Stock Lucas lasted 15 years?
No need to spend the extra money if you have not done any motor mods.
Old Oct 1, 2009 | 06:34 PM
ainiguez's Avatar
I don't know if it is the original, I bought the truck last year.
Old Oct 2, 2009 | 10:49 AM
ainiguez's Avatar
I tried an MSD Ignition coil 8202. Didn't work, same symptoms. The one I removed was a Bosch.
Old Oct 3, 2009 | 12:33 AM
ainiguez's Avatar
It turns out that the real issue was a cracked rubber cover to the connector to the ignition "amplifier". Coolant got in it when I replaced the top radiator hose last week. Although we had checked the distributor cap, I wouldn't have thought of the module if someone on one of the forums (fora?) hadn't mentioned it. An hour with a hair dryer and all original parts are working again.
trialrun
Nov 11, 2014 08:41 AM
b_woodroaster
Nov 5, 2010 08:54 AM
GoldDiscoII
Jan 31, 2009 09:09 PM
Discochick
Feb 19, 2008 10:31 AM
GoldDiscoII
Dec 3, 2006 12:06 PM
