Ignition Key Lock spins freely
Old Oct 31, 2015 | 10:19 AM
sobieski's Avatar
5th Gear
Default Ignition Key Lock spins freely
DII 2004
I know there's lots of post about key hard to turn, stuck, broken off, etc.
My issue is slightly different:
I have an ignition key that just spins freely in the barrel unless you really play with it, do a rain dance, and pray to the Rover gods.
I have a used ignition lock assembly in-hand.
Does the lock assembly need power in order for the key to turn in the barrel?
Upon opening the used lock assembly, the key was in the barrel and turned - like to position 1. I "turned it off" and removed the key. Now, the key will go in but will not turn in the barrel. What am I missing?
I plan to try and use the "new" assembly's parts to repair the one in my truck so I don't have to sheer off off the one in my truck and mess with key cutting, etc., but am open to suggestions.
Thanks in Advance.
Old Oct 31, 2015 | 05:58 PM
dr. mordo's Avatar
This thread should give you some ideas:
https://landroverforums.com/forum/di...ock-fix-35422/
I'd probly pull the barrel and figure out what's wrong. You could also swap the old barrel into the new ignition.
binvanna
Oct 26, 2012 05:07 PM
srfnsno99
Aug 28, 2011 10:46 AM
meltdowndave
Jul 4, 2010 05:13 AM
kkg10
Freelander
Jan 3, 2010 02:55 PM
fanatic516
Jul 31, 2007 12:43 AM
