ignition key stuck LR3
Old May 18, 2016 | 08:26 AM
CATTIVA73's Avatar
Default ignition key stuck LR3
well after resolving the flooding issues on my '06 LR3 now the key gets stuck in the ignition after I turn off the car ...is there a solution to this? I tried shifting out of park and back but nothing.. the only way I can get it out is by disconnection the battery...
Thanks
Old May 18, 2016 | 08:28 AM
chubbs878's Avatar
you posted in the wrong sub-forum. This is for D-2 people
Old May 18, 2016 | 09:54 AM
mln01's Avatar
I don't know anything about LR3s but on a DII the symptom you describe can be caused by a failed or misadjusted XYZ switch, also known as a neutral safety switch or starter inhibitor switch. It is mounted on the left-hand side of the transmission. A quick Google search informed me that the LR3 also uses a transmission made by ZF so it may use a similar XYZ switch setup.
Old May 18, 2016 | 02:00 PM
abran's Avatar
No XYZ on the LR3.
ImQuattro
May 1, 2014 08:36 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
8413b
Jul 27, 2007 07:20 PM
moneypit37
Nov 27, 2006 02:20 AM
Tayo
Sep 10, 2005 01:13 AM
