The illusive misfire cause
Old Jun 10, 2016 | 12:02 PM
  #21
Ed Whiston's Avatar
Originally Posted by Charlie_V
Wait, one of my suggestions panned out?!
Wahoo!
Charlie - you're the man for this suggestion!
Old Jun 10, 2016 | 01:16 PM
  #22
DiscoBuckeye's Avatar
Originally Posted by Ed Whiston
[LIST=1][*]
Yes, absolutely!
I had 13 codes before I secured that wire including a mis-fire on #2. When I reattached I went to zero codes and running WAY better. Still a little hesitation while accelerating, so there is some additional maintenance I need to do, but the loose wire was apparently the main source of the problem.
I'm going to put a second ground wire on the other side when I get to it.
I am going to have a look at mine.
Old Jun 10, 2016 | 02:12 PM
  #23
Charlie_V's Avatar
I thought I glimpsed yours in the famous video around the brake cleaner time... I'll have to find it again.
Old Jun 10, 2016 | 02:20 PM
  #24
I just remember not catching fire. Thats a good memory for me.
Old Jun 27, 2016 | 09:20 AM
  #25
Ed Whiston's Avatar
Here's the final result of what was going on in this thread. Frequently with a Disco there is not one problem that generates a performance issue. In this case there were several problems that led to misfires, hesitation and all sorts of non-specific issues. Here's what I wound up doing:
- new O2 sensors, they were over recommended mileage and needed to be replaced anyway
- new MAF, believe it or not, it makes a huge difference
- loose ground wire was throwing all sorts of confusing codes and warning lights
- cleaned throttle body and checked all vacuum hoses, found split and repaired it
- replaced the battery under warranty - after several tests it showed a bad cell - buy a good battery, it's worth it, these vehicles draw a lot of electical power
All of the above I did myself and it got me to "'running OK" but not running right and still getting random codes. So, I but the bullet and went to a good mechanic. He replaced coils, wires and plugs, then rewired and replaced the knock sensors. I am right with no, codes, no hesitation and no warning lights. Total cost is about $1,500. There was not a single issue causing these problems, it was sort of everything and took quite a while to chase the problem and nail it down.
NOTE ABOUT KNOCK SENSORS: I have seen a lot of posts about the wiring of knock sensors and did some digging around. There was apparently advice out there at some point to disable them in order to improve gas mileage. That was bad advice and will eventually generate misfires while going up hills, which will translate into misfires any time the engine is under strain. The knock sensor retards timing to avoid preignition when under strain, without them the preignition will occur leading to other issues over time. My advice to you is to check the wiring and repair it it if someone monkeyed with it, and make sure that the engine is getting all of the inputs that the engineers designed into it.
Hope this thread is helpful to others!
Old Jul 1, 2016 | 09:08 AM
  #26
Charlie_V's Avatar
Thanks for posting the solution! So few do that. for $1500 plus some parts and time I bet your rover will return the kindness for years to come.
BamaDisco2
Feb 4, 2016 09:27 PM
schwaggy
Jan 24, 2016 09:44 PM
Gromeo
Jan 24, 2013 03:41 PM
pdowning6
May 12, 2012 10:30 AM
Disco Den
Mar 28, 2010 12:42 PM
