:) I'm back in work, but still having brake issues
Old Dec 29, 2012 | 12:48 PM
TRIARII's Avatar
Originally Posted by jfall
You need to totally bleed it first so that there are only a few inches of pedal travel ever.
I have used a hose on each fitting into a jar of brake fluid.
Then you pump the pedal 10 times or so for each wheel
and keep the nut open.
The idea here is that when it does suck a little back up the linke - it is sucking on brake fluid which is sucking up hill and therefore will effectively block air and speed up the bleeding process.
so hypothetically this can be done alone without assistence and without any self bleeding kits yes? Open one bleed screw at a time, attach rubber tubing and let the other end hang down into a bottle filled with clean brake fluid, Pump the brake pedal 10 times or more then close up the screw and repeat on all four wheels. This fuseable? or am I missing something?
00rove
Mar 6, 2012 07:10 AM
DiscoDad
Dec 19, 2010 06:51 PM
tex599
Jun 22, 2009 10:03 AM
mestupstud
Dec 12, 2007 09:57 AM
russ00001
May 9, 2006 08:53 PM
