IM removal and ignition cable replacement.
Old Mar 17, 2020 | 09:08 PM
Carlos Man's Avatar
Default IM removal and ignition cable replacement.
Hey guys I’m changing my ignition wires and have the IM off.... anything I should check, clean, change, while it’s off?
also what’s your take on changing the coil pack... I’m having a misfire in cylinder 4 and changing the spark plug didn’t help.
Old Mar 17, 2020 | 10:54 PM
redwhitekat's Avatar
Coil packs are cheap Rock auto
use 8mm wires.
Old Mar 18, 2020 | 04:37 AM
Carlos Man's Avatar
use 8mm wires.
Got Magnecor Performance Electrosports Wires BOSCH Engine 8.0MM from AB
and the coil pack set from Lucky8.
wish I could find a relocation kit
Old Mar 18, 2020 | 07:59 PM
And get rid of that ****ty dexcool
Old Mar 18, 2020 | 08:17 PM
Carlos Man's Avatar
I’ll do a water pump and thermostat job this summer..
Old Mar 19, 2020 | 01:08 AM
Richard Gallant's Avatar
You could hit your injector connections with some electrical cleaner and refresh the Injector O-rings
Old Mar 20, 2020 | 02:18 PM
Carlos Man's Avatar
Noticed this once I got the coil pack out... what do you all think?
Old Mar 20, 2020 | 02:29 PM
Carlos Man's Avatar
I smelled the fluid around the fuel line and it’s pretty odorless... I’m thinking it’s coolant... could it have traveled back there?
I did have a slight leak....
I have the new hose ready to be installed
The Deputy
16
Nov 4, 2022 07:11 PM
britguy
Sep 20, 2019 05:46 PM
dmannrover
Jul 31, 2019 11:57 AM
The Deputy
Dec 9, 2017 01:08 PM
RoverLover21
Nov 21, 2009 02:41 PM
