Immobilizer problem
Old Jul 24, 2025 | 10:23 PM
tybmx420's Avatar
Default Immobilizer problem
So I have a 01 d2 and my girl first lost the original key so I got everything related to the security system outta another d2 with the key and it ran fine for a while but then the battery kept having a parasitic draw and kept killing the battery if left connected and then it just stopped starting after I parked it and shut it off. Only thing that is coming up on a scanner is the immobilizer but the security light is not on and I’ve tried everything to fix it except going into it on a fancy scanner that will be able to relearn the immobilizer due to not being able to afford one at the moment. Any info or help on getting this fixed will be greatly appreciated. Thank you for your time.
Old Jul 25, 2025 | 06:57 AM
Kurgan's Avatar
I'm having the same problem with my 99 4.0 Thor V8, battery died due to parasitic draw, battery replaced, car refuses to start, no power to fuel pump, no spark.
Old Jul 25, 2025 | 09:22 AM
Brandon318's Avatar
Go to my profile and check out my recent thread on no-start issues. Lots of helpful info in there that might aid in solving this.
Old Jul 25, 2025 | 06:03 PM
Extinct's Avatar
Just rent the nancon and turn it off. https://extinctmotorsports.com/nanoc...eek-rental-55/
mollusc
Aug 28, 2023 03:43 PM
Amiee Pentzer
Range Rover L322 (3rd Gen)
Apr 1, 2020 11:04 AM
Bren howie
Mar 21, 2019 03:34 AM
Tricked306
Nov 9, 2018 01:54 PM
gasm
Aug 11, 2011 12:35 AM
