Importing a diesel motor from the UK to the US
My company supplies 300tdi, and TD5 take out kits. have a look at our website GLOBALLANDROVERS - Home or our facebook page www.facebook.com/globallandrovers
we can provide references and currently supply our kits to some US dealers in Florida, North carolina, Arizona, Ohio, New Jersey, and have had enquiries from many more, this month December we are offering a 10% discount on all our kits.
300tdi Conversion for Auto V8 D2
Discovery 300tdi auto kit for Discovery 2
Full engine with harness , full engine bay kit with all hoses, pipes, radiator pack, auto gearbox with transfer box complete , full bulkhead harness with dash unit front & rear prop-shafts
£3450 Plus Shipping.
How to do the conversion:-
Gearbox/transfer box
Remove old gearbox bolt replacement 300 auto back in the same place has was the V8 auto, no mods needed just bolting in.
Engine
Remove old V8 engine remove/cut off engine mounts on chassis, fit 300tdi engine to replacement auto box bolt up, before welding on 300 engine mounts to chassis, fit replacement radiator with the frame & intercooler as 1 unit, fit fan cowling to radiator frame, fit fan to engine adjust height of engine until fan fits into fan cowling, now allow a little height to the engine & weld engine mounts to the chassis; after engine is tested on its mount, check that the fan still fits into cowling, now fit all water hoses, intercooler hoses, air filter box etc.
Wiring harness for engine
You can use the old engine harness from the V8 engine, some wires to do not to content & use the ecu to run the rest of the cars electrics; all depends if you still have air bags fitted & height control, Rev counter wire to alternator, if it does not work then wire to speed control switch on bell housing speed sensor, the other way to wire is to remove the dash harness completely & fit the 300tdi harness & clock pod & use the 300 engine harness, I hope this info helps.
Inquiries to globallandrovers@gmail.com or call 240 249 0507.
__________________
Land Rover Defender Specialist.
We ship worldwide by container and RoRo.
Engine
__________________
I just brought in a 200TDI. You put the engine on a pallette, fill out the engine import form and either pay an Importer like Uncle Douglas from Defendersource to bring it in for you like I did, or go direct to the shipping company.
There is a guy on Vancouver Island in BC Canada that imports TD5's and installs them in D2's along with 5-speed...or you keep auto. i'll try to fins his info. Saw something a little while back and poem with him. He's done a few.
roverdisco1017
May 5, 2021 09:56 AM
DrivinWest
Jul 22, 2006 06:11 PM
dubaiguy
Jul 22, 2006 11:06 AM
