Increasing ground clearance?
Old Nov 15, 2012 | 12:47 PM
mirrajumper's Avatar
Default Increasing ground clearance?
There are front steering replacement parts available that increase ground clearance without having to install lift kit. Do you guys think this is a good idea?
Old Nov 15, 2012 | 01:50 PM
hilltoppersx's Avatar
why? just get the terrafirma or rte heavy duty tie rod and track rod. what size tires are you running
Old Nov 15, 2012 | 01:56 PM
ZGPhoto's Avatar
No there aren't. You can't increase ground clearance with front steering replacement parts. Unless you're referring to literally ONLY those parts being higher.
Old Nov 15, 2012 | 02:12 PM
Big Jim Swade's Avatar
Taller tires are the only way to increase ground clearance at the differential. A suspension lift won't give you any increased ground clearance unless you add taller tires with it.
Old Nov 15, 2012 | 02:28 PM
Good points. I was thinking of the terrafirma stuff or Lucky8 that just offers a clean and simple way to get some of items " out of the way" best possible. Point being if some of the suspension items are needing replacement anyway - there are great choices to be had without choosing OEM stock everytime.
lr2001silver's Avatar
Banned
Just cut your fenders and put some tractor tires on it.
Old Nov 15, 2012 | 02:34 PM
Thats one way to do it.
Old Nov 15, 2012 | 09:17 PM
909wheeler's Avatar
Portal Axles.
kfx4001442
Dec 7, 2012 04:57 PM
RROJ
Jul 24, 2011 07:59 AM
kcirtap
Sep 26, 2007 09:39 AM
freeranger
Mar 29, 2005 06:03 PM
