Induction cleaning, and no smoke? doesnt seem right
Old Feb 26, 2010 | 06:45 AM
elboy0712's Avatar
Default Induction cleaning, and no smoke? doesnt seem right
used the lubro molly product in the pic.... maybe was the wrong choice... thoughts? got my hands on some B-12 made by berryman ... was thinking of trying that out after i have run the engine a bit to get the other stuff out... let me know what you guys think...
Attached Thumbnails Induction cleaning, and no smoke? doesnt seem right-5129_200_100.jpg
Old Feb 26, 2010 | 07:42 AM
How did you do it, something is wrong, either the product used or the method of cleaning.
Old Feb 26, 2010 | 10:32 AM
Disco-Nate's Avatar
I used about 3/4 of a can of sea foam through a vacuum line and didn't get very much smoke, there was definitely some, but not as much as I've heard should come out. 95 DI 139000 miles. did I do it wrong too?
Old Feb 26, 2010 | 05:19 PM
elboy0712's Avatar
Default used the product in my original post
I believe i followed the directions i got from both you and and spike. which were:
start car - disconnect rubber hose from valve cover on passenger side - slowly add fuel system cleaner to this hose (on the side taht i removed from the valve cover, so that it is being sucked into the intake plenum) - started seing a bit of smoke towards the end of the bottle but not much. - shut down the car and waited for 30 mins. - then drover around on the autobahn for 30 mins.... not really anything coming out of the tailpipe. In fact I would say that I have seen less visible exhuast since then.... almost nothing ... weird....
Old Feb 26, 2010 | 06:34 PM
I see that as a good sign, to me that means there was little to no carbon build up.
My truck does not smoke either when I do mine.
I have used the B-12 before, pretty good stuff.
Old Feb 26, 2010 | 09:42 PM
elboy0712's Avatar
Default god stuff
I think ill give the B-12 a try, maybe half the bottle as it seems to be pretty large.... if nothing with that then ill just assume it to be pretty clean ...
Old Feb 26, 2010 | 10:03 PM
smokey73's Avatar
Default Color of the smoke?
What color should the smoke be when doing the induction cleaning? I did mine and it was pure white. Quite a bit - looked like I was doing a white smoke show and then it smoked white for a about a mile or two when I drove it. It would seem if it is removing carbon the smoke should be black. Did I do something wrong?
Thanks
Old Feb 26, 2010 | 10:06 PM
elboy0712's Avatar
obviously i dont know myself as i didnt get smoke but the seafoam video i watched shows white smoke.
Old Feb 26, 2010 | 10:59 PM
hilltoppersx's Avatar
yes the smoke should be white.
elboy0712
Feb 20, 2010 09:37 PM
avking
Jan 11, 2009 09:05 PM
mellyagaunce
Oct 8, 2008 07:55 AM
Phototone
Apr 23, 2008 07:48 AM
Scanner
Mar 24, 2008 02:10 PM
