Injector Size?
I replaced with 19# fords as my old ones leaked.
If you do the math, you need just under 16# @ 80% duty cycle, the ECU will back off the pulsewidth to a 19# injector to get what it needs.
19# at 40psi is good up to 300hp or so. -- Don't get crazy or you'll be pulling them back out.
Do your homework, more injector does not give you more horsepower all things equal.
luck,greg
Well, I don't know the injector m# on an '01, but my '97 DI used 19.2# lucas (stock).
luck,greg
luck,greg
I just didn't want to run too rich. Does it matter what the impedence is? The stockers appear to be high impedance, and I believe the ford ones are low impedance.
jigray3
10-14-2010 06:54 PM
jigray3
10-09-2010 09:27 AM
alpinab7
08-05-2006 08:41 PM
