Injector Size?
Old Mar 27, 2010 | 11:12 PM
TBIAgent69's Avatar
Default Injector Size?
Can someone tell me the injector rating (Lbs) of the stock injectors on an 01 disco?
Old Mar 28, 2010 | 07:38 AM
Just curious, why are you asking?
Old Mar 28, 2010 | 01:26 PM
greg409's Avatar
Well, I don't know the injector m# on an '01, but my '97 DI used 19.2# lucas (stock).
I replaced with 19# fords as my old ones leaked.
If you do the math, you need just under 16# @ 80% duty cycle, the ECU will back off the pulsewidth to a 19# injector to get what it needs.
19# at 40psi is good up to 300hp or so. -- Don't get crazy or you'll be pulling them back out.
Do your homework, more injector does not give you more horsepower all things equal.
luck,greg
Old Mar 28, 2010 | 10:55 PM
TBIAgent69's Avatar
luck,greg
Thanks for the info! I was looking at a set of ford 19# injectors as well. The spray pattern on those is outstanding. I replaced the ones on my Dodge with fords and that alone made a noticeable increase in power and fuel mileage.
I just didn't want to run too rich. Does it matter what the impedence is? The stockers appear to be high impedance, and I believe the ford ones are low impedance.
gmca01
Freelander
Jun 7, 2012 02:03 PM
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
alpinab7
Aug 5, 2006 08:41 PM
92swbcounty
Jul 20, 2006 08:26 AM
