Injectors? Or maybe something worse...
Old Dec 6, 2013 | 12:30 AM
kristoffersmith's Avatar
Default Injectors? Or maybe something worse...
Hi I have a
2000 disco
162k miles
Regular oil changes every 5k
Use only premium fuel
This is my first real problem with my engine. I'm getting a couple codes and a rough idle and start along with sudden fluctuations in power when acc hard. I also have as light tick coming from the area of the injectors.
I can't find what my codes where but I hade two that I'm concerned with. Knock sensor bank one and misfires on cyl 5
I'm hopping it's just a the injector giving me all this trouble but I haven't dealt with this kinda issue before. Should I replace just the injector for cyl 5 and if so where the best place to get one?
Old Dec 6, 2013 | 05:49 AM
drowssap's Avatar
the knock sensor is one bolt on the side of the block. Clear your codes and see if the #5 misfire comes back. the actual code numbers are very important.
Old Dec 6, 2013 | 12:11 PM
0304Disco's Avatar
Swap knock sensors from left to right and see if the code moves to the right bank. If it stays on the left sounds probably have a bad injector.
Old Dec 6, 2013 | 02:48 PM
dusty1's Avatar
might give this a read https://landroverforums.com/forum/di...results-62870/
Dodger
Jan 5, 2012 07:54 AM
Timpala`
Feb 2, 2010 05:44 PM
Jull
Jan 8, 2009 04:26 PM
mellyagaunce
Oct 8, 2008 07:55 AM
Jawbox
Oct 10, 2007 09:14 AM
