Inline PCV:
Old Oct 13, 2021 | 09:36 PM
  #121
Extinct's Avatar
Originally Posted by donniefitz2
So, for those who have done this, any negative side effects? I would think it could possibly cause a rough idle since the PCV valve that's being put in isn't really dialed in for this engine. If at idle it pulls too much air, it could act like a vacuum leak. But, that's just theory. Also, has this actually stopped anyone's valve cover leaks?
Every other vehicle on the planet runs a PCV, some more complicated than other but the factory LR baffle is a disaster. No adverse affects, stops not only valve cover leaks but front seal, intake, cam sensor, and others. This is what happens if you run with a plugged baffle.
Old Oct 13, 2021 | 11:06 PM
  #122
Gripen's Avatar
Yikes.
Old Oct 13, 2021 | 11:50 PM
  #123
donniefitz2's Avatar
Wow, that's nasty looking. Thanks for confirming that it works. That oil separator is a strange design choice for sure.
Old Oct 15, 2021 | 05:53 PM
  #124
I did the mod. I was able to get both the plastic nipple and the brass post out with ease. I'm guessing since my Disco only has 83,000 on it, things aren't quite corroded in place yet. My oil separator was really clogged and I'm guessing that's why my valve covers have started sweating a little oil.
After doing the mod, no noticeable difference of any kind, which is a good thing.
One of my motivations for doing this is, I noticed a slight bit of oil consumption at high speed/rpm on road trips (1/4 quart for 800 miles, many mountain passes). My theory is, because pressure is building in the crank case, not only where gases blowing by the rings, but some oil as well in the higher RPM range (3-4k).
I'm hoping this modification solves that problem. I'm going to test it tomorrow as I head for the high country in AZ for a Land Rover Owners off road trip. Checked my level today and I'll check again tomorrow after all the mountain driving.
Old Jan 18, 2022 | 04:46 PM
  #125
SWM's Avatar
SWM
Thanks for the mod and great directions. I completed it yesterday for my '04. Fingers crossed it helps with my frame rust prevention system working too much.
I had a heck of a time getting the tube out of the cover. If I had it to do over again, I would listen to others and use more penetrating oil and let is sit overnight instead of being impatient. I got the Deutsch version (PCV147) and it treaded in just fine as expected. Great tip with the 13mm and extension to get it back in straight too.
With 79K miles the components coming out didn't look too bad but it's hard to tell when I had to drill it out.
Best4x4
Dec 17, 2021 12:27 PM
bcurtman
Oct 8, 2019 01:28 PM
lance5x2t
Mar 8, 2015 01:25 AM
Phatrowles
Oct 1, 2013 06:48 PM
bosshogt
Jul 23, 2011 10:01 AM
