Inline thermostat mod shakedown
Old Sep 3, 2019 | 12:33 AM
Jason_B's Avatar
Default Inline thermostat mod shakedown
Okay, I am going to install the the inline thermostat on my 2004 D2. Here is what I ordered:
Meziere WN0071 Inline Thermostat Housing
Gates 21719 Lower Radiator Hose
Gates 23405 Coolant Hose Gates 23405 Coolant Hose
Stant 45358 SuperStat Thermostat - 180 Degrees Fahrenheit
Anything else I need or anyone have any tips or tricks?
Thanks!
Old Sep 3, 2019 | 07:02 AM
Nosugar0carbs's Avatar
Hose clamps, coolant. Water wetter. Temperature gauge
Old Sep 3, 2019 | 08:44 AM
zuke's Avatar
Don't cut your shroud. Don't need to
Old Sep 3, 2019 | 01:57 PM
redwhitekat's Avatar
Waterweter is for water not coolant
Old Sep 3, 2019 | 04:04 PM
Bom2oo2's Avatar
For lower hose, best fit is Gates 22073,.(fits perfect),, For inline T-stat housing 1.25" is too skinny, Best fit is 1.33" = 34 mm.
(Edit), And you need to put a bleeder in the top radiator hose that runs over fan shroud, makes bleeding very easy.
Old Sep 3, 2019 | 05:05 PM
Rlozano's Avatar
Also make sure to drill a hole in the base of the thermostat if it doesn't already have one and make sure that the hole sits at the 12 o'clock position when installing it inside the housing. If this is not done bleeding is very difficult.
Old Sep 4, 2019 | 12:24 PM
Jason_B's Avatar
Sorry for the double post, do you have a part number for your preferred housing? Thanks.
Old Sep 4, 2019 | 05:31 PM
Bom2oo2's Avatar
Sorry, I don’t have the part # for 1.33” = 34mm housing, but the same one you bought also comes in that size.
i just used 2 T-stat housings from couple old Volvo’s (244-240) from junk yard, and put them back to back, they work just fine,
have them on both my Disco’s.
Old Sep 4, 2019 | 06:39 PM
05TurboS2K's Avatar
Good call, commonly not known. You're correct! Water works much better for cooling but it'll freeze and it provides no lubrication. Fine for a race motor.
eskiltell
Dec 31, 2017 06:17 AM
batard
Jan 22, 2016 09:54 AM
russburcham
Dec 6, 2012 02:18 PM
ebg18t
Aug 8, 2012 05:44 AM
ATLDisco
Apr 4, 2012 07:00 AM
