Installing A-bar quick question
Hey guys I am installing my A-frame bar today and I have a quick question before I do anything (such as drilling).
The Directions say that the hole for the A bar are pre drilled in the steel fram by the factory. To locate the holes its says to measure down from the top of the numer plate recess (the european number plate recess) 2 inches and in from the sides 1.5 inches. Then it says to open out the to holes and take out two studs. Now my question is, if I drill this is going to be there right? I dont want to have unnessary holes!
Ok so let me know what to do, if you have any tips that would be great too! Thanks guys
Cameron
Cameron
RE: Installing A-bar quick question
Times like these I wish I had an answer. What I'd do if I were you is call the company you got the A bar from and ask them, not only that, call your dealership and tell them what's going on and see what they say.
Someone on this site might have the right answer so you might wait a couple days too.
Thanks for the reply! I actaully went ahead and did it and sure enough the holes where there when I drilled through! The bar went on and screwing it in was a trip but now I have another problem that I addressed in another tread. The bar is on but it is loose, it is screwed in as tight as I possibly can and it seems tight around the screw areas but when i wiggle the top its just not right. I dont get it but I am going to fiddle with it tomorrow!
jthomas
04-17-2013 08:37 AM
endneu913
11-03-2007 03:46 PM
