Installing Drip Edge
Old Aug 30, 2019 | 04:04 PM
mark.ferdinand@gmail.com's Avatar
Default Installing Drip Edge
Hi: I have a 2003 Disco II. I'm trying to install some of the OEM black drip edge that runs along the left-hand side of my roof and wraps around a couple inches around the back corner to the tailgate. Does anyone know how to snap it in place.? I can't figure if I'm supposed to position the top first and then push in the bottom or position the bottom first and snap it in at the tope. Any advice appreciated!!!
Mark
Old Aug 30, 2019 | 05:26 PM
keninnc's Avatar
Default Drip Edge
Just did mine last week.
Top down.
Begin with the rear and slide in under the corner that goes up. Then work your way to the front of the vehicle. The back corner is the hardest part to snap on but once you get it the long section is easy.
Old Aug 31, 2019 | 10:05 AM
Default Drip Rail
Wow ... thanks for the fast response!. So I understand I should begin at the rear corner and work my way forward so that is good to know. I'm still not clear about where to start when I snap drip rail in place. Do I basically do I start at the top edge and snap the rail in place at the bottom as I go along, start at the bottom edge and snap it in at the top as I go along, or does it not matter?
austinlandroverbill
Jul 9, 2022 06:21 AM
Ben Matheson
Jul 29, 2019 08:36 PM
Carlos Zamora
May 26, 2017 05:30 PM
acg
Dec 22, 2013 02:45 PM
errose2002
Nov 18, 2010 09:04 PM
