Roof Rail Extension Installation
Old Dec 14, 2013 | 06:14 PM
acg's Avatar
acg
Default Roof Rail Extension Installation
I have a used pair of roof rail extension which I am looking to install this weekend.
One of my Land Rover local shops advised doing the installation myself as a special guide tool is needed to drill into the holes into the roof.
Has anyone attempted this installation? Just wondering if I can simply remove the rear part of the headliner trim and do the installation myself?
Attached Thumbnails Roof Rail Extension Installation-land_rover_discovery_roof_rail_extension_stc50034aa.jpg
Old Dec 16, 2013 | 08:07 AM
acamato's Avatar
Here are the instructions http://www.pm10000.webspace.virginme...nstruction.pdf
look at step 3,4 & 5. It looks like the original kit provides a drill guide that you drill thru the roof (form the inside) and you use that hole to locate the hole saw and drill form the outside. You need to get the drill guide and gaskets.
Old Dec 16, 2013 | 12:49 PM
acg's Avatar
acg
Acamoto,
U da man!
Thanks for sending the link to the installation instructions. This help me to understand the location of the hole.
I will remove the artic window trim panel to see if I can drill a hole accurately without using the guide tool (which I am missing). If I am not confident in being able to accurately plot the hole position, I will send it to the LR shop for installation.
Old Dec 22, 2013 | 02:05 PM
eitydeuce's Avatar
Where did you get the extensions?
Old Dec 22, 2013 | 02:45 PM
acg's Avatar
acg
I bought a used set from this forum. LR no longer supplies the rail extensions or the cross rails. This is the only site where I know a new set is still available.
Land Rover Discovery Genuine OEM Factory Lamp Guards
Cesargeronimo
Jun 16, 2013 10:15 PM
RoveringAgain
Nov 8, 2009 02:51 PM
discohue
Oct 6, 2009 05:24 AM
RoveringAgain
Jun 10, 2009 02:09 PM
sna77
Dec 19, 2008 09:58 AM
