Installing OEM sunroofs in a DISCO S
Old May 15, 2012 | 08:43 PM
borchera's Avatar
Originally Posted by Spike555
Screw these guys, install the sunroofs, then go to the marina and get some sealant, marine grade.
Then with the sunroofs closed seal them shut, they will still leak, but it wont be as bad.
Seriously, I opened both of mine the day I test drove my truck back in '07, they have not been touched since.
I had to laugh at this because my son and I did/ and are doing the same thing. Tested the roofs on the test drive back in July when we bought the truck and the sunroofs have not been touched since. We just keep thinking they work as is and there is no need for using.
2003 Discovery 127K with high miles service complete.
Old May 15, 2012 | 09:41 PM
bosshogt's Avatar
I think you should do what you want with your Rover and your time. I have sunroofs in my 2003. I open them about everyday in the summer. They do not leak. When they start leaking I will fix the drain hoses as I have seen everyone else do on the forum. Its not rocket science... If you want to go the simple route and skip the wiring. You could use a 4mm to open and close them manually. While you are at it you could paint your headliner.
Shiftonthefly1
Jul 17, 2015 03:44 PM
OEMPartHaus.com
Member Group And Special Buys
May 28, 2015 08:59 AM
sickws6
Aug 17, 2013 07:18 AM
RjBu
Oct 2, 2009 02:28 PM
rjhagan
Jun 4, 2007 04:12 PM
