No power under a load
Old Feb 18, 2012 | 12:56 PM
rholtporsche's Avatar
Default No power under a load
I have a 2003 disco. Service engine soon light flashes and I loose power under a passing gear load around 65-70 mph. My code reader reads a cyl 6 misfire. It has brand new heads and a new coil pack. The land rover "professional" thought this would fix it. It is exactly the same as before I had it fixed -$4700. Any help would be much appreciated.
Thanks
Old Feb 18, 2012 | 01:06 PM
You spent $4700 without getting a 2nd and 3rd opinion?
"Dr. my arm hurts"
"Ok, lets cut it off"
"Ok"
Did he do a tune up? New plugs and wires, what brand of wires did he use?
Are you losing coolant?
Old Feb 18, 2012 | 01:13 PM
Im in the navy, left it at my parent's house 400 miles away, and for my birthday they were going to surprise me and have it fixed. I went a little pale when I found out. A little help here.
Old Feb 18, 2012 | 01:15 PM
I have no idea weather he did wires or not. Not loosing coolant. With the coil pack and heads I supposed he had to do some tuning.
Old Feb 18, 2012 | 01:18 PM
Thank you mom and dad. lol
I too would assume he did plugs and wires but you know what happens when you ASSume.
Swap plug #6 with a different one and see if the misfire follows.
#6 is the 2nd to the last on the right side of the engine (from sitting inside the truck)
Old Feb 18, 2012 | 01:19 PM
Plug wires are new
Plugs and wires are new
Old Feb 18, 2012 | 01:23 PM
Ok, swap plug #6 with a different one and see if the misfire follows.
Do you know what brand of plug wires he used?
Old Feb 18, 2012 | 01:35 PM
The invoice doesn't say what plug wires he used. The plug wires don't have what brand they are on them.
Old Feb 18, 2012 | 01:37 PM
Also. When I got the cyl 6 misfire (before any work was done) I changed all of the plugs. It didn't solve the problem. Same cyl6 misfire as before. The "professional" also replaced the plugs, still cyl 6 misfire.
