Installing a Temp Gauge on a 2003 Disco II
Old Sep 7, 2010 | 09:58 AM
  #21
ShortTom's Avatar
Originally Posted by Bundu
The factory one is crap, it shows cold, hot and replace engine. There has been enough posted about the heat gauge and how **** it is.
Hm, good to know, didn't realize that. All the more reason to get a ScanGauge...
Old Sep 9, 2010 | 02:39 PM
  #22
tito5590805's Avatar
How about a Sticky?
Old Sep 9, 2010 | 07:27 PM
  #23
jycsalas's Avatar
Nice....
Sticky?
I guess it is worthy of the honor....
LOL j/k Keep it up!
Old Feb 17, 2011 | 09:30 AM
  #24
Disco_Fever's Avatar
Isn't there place the temp probe can be inserted without having to buy that big adapter and cutting into the hose?
Old Feb 17, 2011 | 10:44 AM
  #25
Bundu's Avatar
Banned
Yeah, bend over
Sorry, just kidding. I have been thinking of replacing the T with something that is drilled and tapped to take the 1/4 probe and do away with the bleed screw, or have 2 tapped holes to accommodate both.
Another option is to do what the Mustang guys do, drill and tap the intake manifold in the same area where the stock sensor is. I looked at mine when it was off and there is an ideal spot with a flat surface. It takes some commitment though.
Old Feb 17, 2011 | 10:52 AM
  #26
I read this in an old thread on Dweb:
"I used an analog gauge and installed the probe on the pass-side, under the header. There is a Hex plug there. Just remove the hex plug and install the probe."
Anyone know exactly what this guy was talking about?
Old Feb 17, 2011 | 10:59 AM
  #27
Bundu's Avatar
Banned
Possibly one of the block drain plugs?
Was it on a D1 or D2?
Old Feb 17, 2011 | 11:04 AM
  #28
D2. I'm going to look for it tonight.
Old Feb 17, 2011 | 11:12 AM
  #29
Bundu's Avatar
Banned
That's the drain plug next to the knock sensor, it will sit above the engine mount. I have a block in my garage and will go check it out tonight.
Old Mar 8, 2011 | 03:01 PM
  #30
I'm planning on hooking up my sending units tonight, was it determined whether or not this drain plug is an acceptable place for the temp-sensor?
