Installing Terrafirma sliders with tree bars question
Old Dec 24, 2012 | 07:30 AM
  #21
ebg18t's Avatar
Question
Originally Posted by aarongregor
ZG and ebg, I have an 03 so I fall in the middle and will post pics and info when I put mine on. ZG did they effect your lift any?
I didn't measure before and after the sliders. I installed bumpers, winch, roof rack, armor all at the same time. My TF springs were not up to the task so I ended up going with the whole RTE 4"+ kit with Fox shocks (almost $3k) to handle the weight.
Old May 21, 2013 | 06:45 PM
  #22
ZB-30's Avatar
I just picked up a set of these. Looks like it came with 14 sets of nuts and bolts, 7 per side I'm guessing. However there are more holes in the rock sliders than nut/bolt sets. Am I missing some hardware or do you just not use all the holes?
Old May 21, 2013 | 06:54 PM
  #23
ZGPhoto's Avatar
Likely missing some hardware, you should install a bolt in every hole.
Old May 21, 2013 | 07:07 PM
  #24
ZB-30's Avatar
I bought these from Lucky8, I just sent them an e-mail to see what they have to say.
Old May 21, 2013 | 08:53 PM
  #25
Fivespddisco's Avatar
I did not see the Email But you should have a bolt for every hole. Please call tomorrow and ill get you what you need.
Old May 21, 2013 | 09:32 PM
  #26
ZB-30's Avatar
PM sent with a copy of the e-mail I sent. I'll give you guys a call tomorrow, thanks!
Old Mar 3, 2014 | 01:31 PM
  #27
justin_carlson's Avatar
3rd Gear
Did the instructions for the Terrafirma Rock Sliders ever get made? I've been searching the site but have yet to find them. I ordered a pair for my '04 Disco2 and was going to install them later on today.
Old Mar 3, 2014 | 01:47 PM
  #28
ZGPhoto's Avatar
I haven't made any up..no time.
Best to raise the sliders up with a jack and just drill out the holes a bit and install away!
Old Mar 3, 2014 | 04:33 PM
  #29
acamato's Avatar
Thats close to what I did. I jacked them up in place. Made sure they didnt interfere with the doors, marked the holes. Lowered them and drilled out the holes. One of the inside holes (each side) lines up with one of the body mounts, so I didnt put a bolt there. Mine didn't come with enough hardware. It came with 14 bolts, 28 washers and a mix of nuts and locknuts. I needed 18 bolts, got the 4 from HD or Lowes. I used locknuts on all the bolts.
If you have ACE you will have an acellerometer on the pass side sill that needs to be removed and relocated to the slider.
Old Nov 8, 2014 | 06:53 PM
  #30
Robert Booth's Avatar
Heh guys, I have my plastic side trim off and trying to install my tree sliders tonight.
One thing no one mentions, on my truck, the outmost holes line up but I don't have any holes on the inside of the frame. The supplied hardware and fit of the slider looks like I have to drill those inner holes. Did you use a 1/2" bit for the inner holes?
