Installing Terrafirma sliders with tree bars question
Old Nov 8, 2014 | 09:06 PM
  #31
Robert Booth's Avatar
I ran out of time tonight. I'll get back at it in the morning.
Old Nov 9, 2014 | 11:03 PM
  #32
In the cold light of day, the screw that extends from the bracket that stops the bottom half of the passenger side wing from flapping about is nowhere near in the right location to screw
Into the front of the tree slider. Otherwise the other holes look good. Not sure if the panel is in the wrong place, manufacturing defect or just a relocated bracket, but either way, I have to move the bracket tomorrow so that the holes will finally all line up.
Old Nov 10, 2014 | 01:26 AM
  #33
clint70's Avatar
Really interested in seeing some installation instruction / photos of the process. I am looking at ordering these in the next couple weeks.
Thanks
Old Nov 10, 2014 | 09:46 AM
  #34
Will do. It "should" be straightforward.
Removing the plastic trim piece takes around 5-10 minutes a side.
Put the slider on a jack under the sill. You'll need to open the doors again, like when you removed the plastic trim pieces.
Jack the slider up with the front and back plates on the slider wrapping the sill.
If you're fortunate, all the holes will line up, including a screw that protrudes down from the front wing. You'll need to remove the nut that is used to keep that front screw tight (and the bottom of the front wing from flapping around)
Once you have the slider in position, make sure it's sitting flat against the frame, check the doors clear the sliders and then mark the holes on both the front and back of the frame.
Lower the slider, drill out the holes so that your hardware will fit through(I used a 1/2" drill bit).
Then raise the slider again on the jack and this time you can bolt the slider in place.
In my case I have to figure out how to relocate the bracket that is used to keep the front wing tight. If I shaved off the screw to bolt on the slider, the bottom of the wing would be able to move around, so I have to address it.
I'll include pics once I get my slider all lined up.
Old Nov 10, 2014 | 10:19 AM
  #35
ZGPhoto's Avatar
I think you're lucky if you get half of the holes to line up. I'm not sure what Terrafirma used as a template? Maybe a wrecked disco? Maybe they just said, let's drill abstract holes. Not sure, either way they do not line up and we have it as an item note in our system to relay that info to the customer prior to purchase now.
Old Nov 11, 2014 | 11:50 AM
  #36
The holes that almost line up are there to tease you. Best sliders I have ever owned hands down were the Rockstar Fab ones, unfortunately he called it quits.
Old Nov 11, 2014 | 04:12 PM
  #37
acamato's Avatar
If you have ACE, there will be an acellerometer in the way on the pass side sill. Be gentle when removing it. I used a hammer after I drilled out the rivets and had to buy a new one.
I had to drill most if not all the holes. I also had to get hardware from Lowes because there wasn't enough supplied with the sliders. I didn't use the spacers (short pieces of tubing).
Old Nov 12, 2014 | 10:22 PM
  #38
I got this finished today. Embarrassing how long this took.
I'me happy with how it looks, but I'm never installing a set of these ever again plus I put a scratch in one while putting it on so now have to go find some touch up tomorrow before it starts rusting on me
They look pretty good. Anyone have any recommendations for a touch up pen for the sliders?
Old Aug 22, 2021 | 08:21 PM
  #39
sdtimb's Avatar
Here are the instructions from Terrafirma. I'll be installing mine tomorrow. I hope the quality of the sliders are better than the quality of their instructions.
Terrafirma Rock Slider Install Instructions - TF809
disco202
Mar 22, 2021 10:06 AM
drowssap
Jul 28, 2014 01:21 PM
christiansmith6
Jan 7, 2014 07:46 AM
caerb
Jan 12, 2013 01:54 PM
Cosmic88
Jan 21, 2011 08:47 PM
