instrument cluster
Old Sep 27, 2007 | 04:48 PM
okdiscoguy's Avatar
Default RE: instrument cluster
Ok, I have a D1, so I tend to lean to what I have. Checked Rave and it looks like you get a signal from your SLABS ECU (wheel sensors) and one from a sensor on the output shaft of the transfer box. Get under your truck and look for this sensor.
Do you have a check engine light? if there is a difference in the wheel sensors and the tansfer case, you should get a fault.
[IMG]local://upfiles/5440/6FF4A0278FC64A9B8BF056BF23D28BC2.jpg[/IMG]
Old Oct 1, 2007 | 09:49 AM
coldfrez's Avatar
UPDATE
On SaturdayI checked the truck and found that the Cruise Control was non-functional...further investigation showed the fuse had popped.I replaced the fude and took it for a drive, drove it all evening Saturday and all day on Sunday..with no problems. ????????? could it have been an issue with the Cruise control not working?????? the Disco rides real nice, no bucking.....could there be a connection??[sm=dontgetit.gif]
vbkre15
Mar 19, 2010 06:44 PM
riko suave
Mar 18, 2009 04:34 PM
Panic
Feb 23, 2009 01:41 PM
CandiMan
Oct 30, 2008 01:39 AM
Greg
Aug 8, 2007 04:47 AM
