Instrument Cluster Cowl
Old Sep 29, 2012 | 12:25 PM
discobob's Avatar
Default Instrument Cluster Cowl
The cowl has come loose. I see the clips above the instrument cluster, but having no luck. Any subtle tricks to this?
Old Sep 29, 2012 | 12:45 PM
Bkreutz's Avatar
If you lower the steering column all the way down you will see two screws that hold the cowl(or binnacle as it's called in England) in place, these may have come loose(or fallen out)
Old Sep 29, 2012 | 03:18 PM
discobob's Avatar
Actually, they had pulled through. I guess the flanges at the bottom of the holes broke out, because the heads of the original screws were smaller than the diameter of the holes. So I used, you guessed it, drywall screws. Hit the screw heads with a black sharpie, and got a pretty acceptable result. Thanks for the info Bkreutz.
Old Sep 29, 2012 | 04:18 PM
Bkreutz's Avatar
I think most of these have drywall screws in there (mine does) I've also seen washers put under the screws. Seems the binnacle plastic is very thin in that location.
smonk
Jul 3, 2014 05:36 AM
DiscoZen
Apr 21, 2014 07:45 PM
DaveBFoto
Jun 10, 2011 12:22 PM
rewi9d
Nov 25, 2010 11:35 AM
Greg
Aug 8, 2007 04:47 AM
